The CE-compliant TRCN440 Series turbidity analyzers come in three compact models for applications such as drinking water and pure water with ultralow turbidity readings.
The CE-compliant TRCN440 Series turbidity analyzers come in three compact models. The TRCN441 is designed for medium to high turbidity ranges. The TRCN442 targets low-turbidity ranges from 10 to 100 NTU, such as those used in the beverage industry, mining, and water treatment. For applications such as drinking water and pure water with ultralow turbidity readings below 10 NTU, there’s the TRCN443 version. The analyzers are lightweight with the NEMA-4X (IP67) and include local indication, transmitter outputs, and control outputs.Omega Engineering Inc., One Omega Dr., Stamford, CT 06907, (203) 359-1660, www.omega.com
