Ball valves -- Omega Engineering Inc.
The BVP70/BVP80 Series of pneumatic and electric-actuated ball valves feature stainless-steel external trim and FKM O-Rings Standard. The valves are designed to operate using 50 to 125-psi air supply and its direct-valve stem coupling to actuator shaft minimizes backlash. Electric actuators feature two 1/2-in. NPT conduit ports and integral thermal overload protection.Omega Engineering Inc., One Omega Dr., Stamford, CT 06907, (203) 359-1660, www.omega.com
