Nonmetallic cylinders -- Polygon Co.
Nov. 24, 2009
Nonmetallic cylinder assemblies for pneumatic actuators made with high-strength composites and plastics.
Nonmetallic cylinder assemblies for pneumatic actuators are made with high-strength composites and plastics such as Delrin, ABS, or UHMWPE. The assemblies resist corrosion and outlast metal counterparts. The lightweight tube has a smooth-bore finish for good seal life and lubrication retention. The impact-resistant tube can withstand a 1-kg shock unlike a metal cylinder.
A glass-filled composite guide rod supports load carrying and works well when coupled with a Polylube Guide Rod bearing. Rod ends can be attached with composite dowel pins to complete the assembly without metals. The cylinders withstand 100 to 125-psi working pressures.
Polygon Co., 103 Industrial Park Dr., Box 176, Walkerton, IN 46574, (800) 918-9261, http://www. polygoncomposites.com
How the Parvalux Modular Range Can Help with Your Next Project
March 6, 2025
At Parvalux we can help you configure a solution to test for your project very quickly. We will dispatch your order within 72 hours.
What is a PMDC motor?
March 6, 2025
Shop high-quality PMDC motors at Parvalux. With a compact design and impressive performance, our permanent magnet DC motors are a popular choice.
The Different Types of Gearboxes
March 6, 2025
There are many types of gearboxes to choose from when creating a solution and with increased torque demands they have become significant.
