Direct-acting pneumatic valve -- Mead Fluid Dynamics, a Bimba Co.
Nov. 24, 2009
The Isonic V2 Series valve is a two and three-way, solenoid-operated, direct-acting pneumatic valve.
 The Isonic V2 Series valve is a two and three-way, solenoid-operated, direct-acting pneumatic valve. With flow ranging from 0.01 to 0.05 Cv, the V2 is available with multiple voltage and electrical connection options in both normally closed and normally open styles.
The design lets flow channels be molded directly into polymer body sections, eliminating abrupt air-path changes associated with cross drilling. The resultant ribbonlike paths create near-laminar flow with little pressure drop. Built-in, push-to-connect collets allow for simple tube and manifold connections in seconds.
 Mead Fluid Dynamics, a Bimba Co., 4114 N. Knox Ave., Chicago, IL 60641, (773) 685-6800, www.mead-usa.com
