Static bulkhead connectors - Pneumadyne Inc.
Nov. 6, 2009
Static bulkhead connectors connect multiple tubing lines in a control panel or on a machine.
 Static bulkhead connectors connect multiple tubing lines in a control panel or on a machine. The connector’s one-piece design features ¼ and 5/32 push-in connectors or ¼-28-UNF threads and accommodates four to 12 tubing lines. Available body styles include push-in, push-in to threaded, and threaded. The connectors are black anodized for corrosion and wearresistance and a Buna-N O-ring provides a tight seal when mounted. Port numbers etched in both sides provide easy line installation and identification.Pneumadyne Inc., 14425 23rd Ave N, Plymouth, MN 55447, (763) 559-0177, www.pneumadyne.comRS# 446
March 18, 2025
March 18, 2025
March 18, 2025
March 18, 2025
