Machinable wear-resistant nylon tubes
Oct. 1, 2009
The wear-resistant nylon Nylatron NSM comes in a broad range of tubular shapes that can be machined into bearings, bushings, and wear parts.
The wear-resistant nylon Nylatron NSM from Quadrantepp, Reading, Pa., comes in a broad range of tubular shapes that can be machined into bearings, bushings, and wear parts. It is said that Nylatron NSM has 5 times more wear life than other “premium” cast nylon materials.
