Servomotor with Analog Tachometer
Sept. 24, 2009
The Model MMP-D22-376F-24V T-07 dc servomotor features an integral analog tachometer.
The Model MMP-D22-376F-24V T-07 dc servomotor features an integral analog tachometer. The motor mounts with four face-mount M5 threaded holes, equally spaced on a 40-mm diamond B.C. The reversible servomotor is rated for 35-oz-in. torque at 2,600 rpm and 210-oz-in. peak and requires just 3.4 A at 24 Vdc to generate full load torque.
Standard options include custom output shaft diameters and lengths, mounting flanges, 80-Vdc and 36, 48, and 60-V motor windings, 1.0, 3.0, 7.0, and 14.0-V/Krpm tachometer voltage gradients, 3:1 to 729:1 planetary gear ratios, and 8-A continuous, 15-A peak analog command.
Midwest Motion Products
10761 Ahern Ave. SE
Watertown, MN 55388
(952) 955-2626
www.midwestmotion.com
Jan. 23, 2025
Jan. 17, 2025
Jan. 17, 2025
Jan. 17, 2025
