Long-Travel Two-Axis Stage
Sept. 24, 2009
The LT490-450-EDLM is for laser machining or other extended travel applications where precision positioning is critical.
The LT490-450-EDLM is for laser machining or other extended travel applications where precision positioning is critical. The fully enclosed two-axis stage with 450-mm stroke features 500 mm/sec maximum speed with acceleration of 5 m/sec2 and 1-micron accuracy with ±0.5-micron repeatability in each direction. The system includes iron-core linear motors, linear guideways, linear measuring system, and E-chain cable carriers.
Steinmeyer Inc.
56 Middlesex Turnpike
Suite 200
Burlington, MA 01803
(781) 273-6220
www.steinmeyer.com
