Planetary-Gear Reducers
Sept. 25, 2009
The PE Series of planetary gear reducers, for servo or stepper-motor applications, come in both 50 to 118 mm and NEMA-17 to 42 output faces.
The PE Series of planetary gear reducers, for servo or stepper-motor applications, come in both 50 to 118 mm and NEMA-17 to 42 output faces. The ready-to-mount Series is available in five standard frame sizes and offers 10 to 135-Nm maximum torque and 3:1 to 1,000:1 reduction ratios. The closed unit is maintenance-free.
GAM Gear
901 E. Business Center Dr.
Mount Prospect, IL 60056
(888) 426-7117
www.gamweb.com
