Pneumatic air cylinders - AutomationDirect
Sept. 24, 2009
The Nitra line of pneumatic air cylinders now includes a series of stainless-steel, round-body, nonrepairable actuators.
The Nitra line of pneumatic air cylinders now includes a series of stainless-steel, round-body, nonrepairable actuators. Type 304 stainless-steel cylinder bodies are double rolled-in construction with high-strength aluminum alloy porting ends. Single and double-acting models with nose, pivot, and double-end mounting options are available, as are some cylinder models with magnetic pistons for position indication. The Series includes 7/16 to 2-in. bore sizes and depending on bore size, ½ to18-in. stroke lengths. Mounting brackets, nuts and rod clevises are available.
AutomationDirect, 3505 Hutchinson Rd., Cumming, GA 30040, (800) 633-0405, www.automationdirect.com/pneumatic-cylinders-disposable
Jan. 17, 2025
Jan. 17, 2025
Jan. 17, 2025
Jan. 10, 2025
