Pressure-control valve with safety function - Hawe Hydraulics
Sept. 22, 2009
The type CLK pressure-control valve has an added safety function that provides operational ease in hydraulic systems where temperature increases and/or external load peaks can cause problems.
The type CLK pressure-control valve has an added safety function that provides operational ease in hydraulic systems where temperature increases and/or external load peaks can cause problems.When closed, the seated valve is leak-free, eliminating the need for additional check valves or continuous refeeding. The valve offers 5.8-gpm flow at 380 bar (5,500 psi) for systems with a maximum pressure of 500 bar (7,250 psi). Built as a screw-in cartridge valve, other versions are available for mounting within valve banks, reducing the pressure for subsequent valves or as part of the NG6 intermediate plate for individual pressure control.
Hawe Hydraulics, 9009-K Perimeter Woods Dr., Charlotte, NC 28216, (704) 509-1599, www.hawehydraulics.com
