Space-Saving Drum Motor
Sept. 8, 2009
Drum Motor 127i features an internal gearing system with a 97% efficiency that lowers energy consumption and reduces noise levels.
Drum Motor 127i features an internal gearing system with a 97% efficiency that lowers energy consumption and reduces noise levels. The thermally protected motor meets IP67 protection standards and features spring-loaded and labyrinth seals that prevent contamination and oil loss in conveying systems that operate in foodprocessing and high-demand industries. The internalgearing system features no external moving parts. The motor is available with three-phase motors and has a conveying speed up to 315 fpm with 1.0 hp. It can operate in temperatures up to 104°F with oil changes recommended every 20,000 hr. Options include a stainless-steel exterior, rubbing lagging, mechanical backstop, parallel shell (no crown), sprocket mounting, and matching idler pulleys.
Interroll Corp.
3000 Corporate Dr.
Wilmington, NC 28405
(800) 830-9680
www.interroll.us
