The 3300 Series pressure transducer is designed for low-pressure applications that demand small size, low cost, high accuracy, and stability. The transducer’s all-stainless-steel wetted parts and all-welded construction make it compatible with harsh chemicals and environments.
Available in pressure ranges from 15 to 250 psi, the unit is capable of operating at –40 to 257°F. The transducer is available in voltage, current, and ratiometric outputs, with a wide selection of connectors, pressure fittings, and mating connectors.
Gems Sensors Controls
One Cowles Rd.
Plainville, CT 06062
(800) 378-1600
www.gemssensors.com
