Product Spotlight: Liquid-Tight Fittings and Flexible Tubing
Aug. 18, 2009
Heyco-Flex III liquid-tight fittings and flexible tubing are designed for quick, easy, and permanent assembly.
Heyco-Flex III liquid-tight fittings and flexible tubing are designed for quick, easy, and permanent assembly. For use in both wet and dry applications, the products resist corrosion, oil, weak acids, and saltwater. The fittings and tubing are flame retardant, nontoxic, and UV resistant. The tubing doesn’t need threading for installation, which eliminates cutting the tubing and creating leak paths. Made of nylon, the fittings and tubing are rated for Type 3R applications and provide maximum flexibility for use in tight quarters. Mounting brackets are available.
Heyco Products Inc.
Box 17
Toms River, NJ 08754
(800) 526-4182
www.heyco.com
Aug. 29, 2024
Aug. 29, 2024
Aug. 28, 2024
Aug. 28, 2024
