New Products: Tools for Turret Lathes
July 31, 2009
A new line of live tools for turret-lathe applications overcome the duty-cycle limitations of standard tools
A new line of live tools for turret-lathe applications overcome the duty-cycle limitations of standard tools. Unlike existing tools that are restricted to limited run time due to frictional heating of the bearings and seals, the Planet Live Tool (PLT) uses a patent-pending bearing lubrication and cooling system. The PLT has no restrictions on cycle time or duty cycle, allowing near-continuous machine cycles on turret lathes and a reduction in the number of tools. Jobs that once had to be run on a multispindle machine can now be done on a turret lathe.
Planet Products Corp.
4200 Malsbary Rd.
Cincinnati, OH 45242
(513) 984-5544
www.planet-products.com
