New Products: Photoelectric Sensors
July 21, 2009
The Series 3130 photoelectric analog sensors feature a 10 to 100-mm sensing range, temperature stability between –25 and 55°C, and outstanding repeat accuracy.
The Series 3130 photoelectric analog sensors feature a 10 to 100-mm sensing range, temperature stability between –25 and 55°C, and outstanding repeat accuracy. The sensing range is independent of the color or surface structure of the object to be detected. The sensor features a 500-Hz bandwidth, voltage of 0 to 5 or 0 to 10 V,) and a 1 to 5 or 4 to 20-mA current out. The devices are fully potted, equipped with glass windows and are IP67 compliant.
Contrinex Inc.
2 Business Park Rd.
Old Saybrook, CT 06475
(866) 289- 2899
www.contrinex.com
