Server for industrial use - Newport Electronics Inc.
June 25, 2009
The 3rd Generation iServer MicroServer has a 32-bit microprocessor based on ARM technology with 72-MHz speed. The iServer lets users put anything on a network without ...
The 3rd Generation iServer MicroServer has a 32-bit microprocessor based on ARM technology with 72-MHz speed. The iServer lets users put anything on a network without writing any codes. The device features 10/100 Ethernet, dynamic Web server, full IP stack, Modbus protocol support, e-mail notifications, SNMP traps, programmable I/Os, firmware upgrade over Ethernet, authentication, and access restrictions for security.
Three versions are available: An embedded MicroServer for OEM’s to network enable their products; an industrial MicroServer that mounts on a standard DIN rail; and a wall-mount MicroServer for most commercial and IT applications.
Newport Electronics Inc., 2229 South Yale St., Santa Ana, CA 92704, (714) 540-4914, www.newportus.com
