Product Spotlight: Positioning Arms for Enclosures
June 16, 2009
Syspend Vertical Motion Arms for HMI enclosures and devices allow for easy adjustment
The Syspend Vertical Motion Arms for HMI enclosures and devices allow for easy adjustment. The system, which includes a monitor and keyboard arm, supports up to 125 lb and its field-adjustable counterbalances let users set and reset lifting force to accommodate weight changes due to load and equipment changeouts. Multiple mounting options facilitate flexible work cell and ergonomic workspace layouts. Depending on the model, the enclosure and arm can be swiveled up to 330°, with swivel stops available in 30° increments; monitor and keyboard arm swivels 340° at the monitor end, and 180° at the mounting end.
The HMI device and arm reduce repetitive motion injuries and lessen worker back, neck and eye strain.
Hoffman Enclosures
2100 Hoffman Way
Anoka, MN 55303
(763) 421-2240
www.hoffmanonline.com
Aug. 29, 2024
Aug. 29, 2024
Aug. 28, 2024
Aug. 28, 2024
