High-precision miniature shaft coupling -- R+W America L.P.
June 4, 2009
The MK1 bellows couplings allow for increased bore diameter within a given coupling size through the use of radial setscrews with unique dismounting grooves. The coupling helps ...
The MK1 bellows couplings allow for increased bore diameter within a given coupling size through the use of radial setscrews with unique dismounting grooves. The coupling helps adapt between shafts with a large difference in size. The coupling’s stainless-steel bellow compensates for axial, lateral, and angular shaft misalignments simultaneously, while operating with zero backlash and high torsion resistance.
Available torque ranges are 0.05 to 10 lb-in. and bore sizes from 1 to 28 mm.
R+W America L.P., 1120 Tower Lane, Bensenville, IL 60106, (630) 521-9911, www.rw-america.com/miniature_couplings/index.html
