Lightweight aluminum spline shafts are treated with a proprietary low-friction TFE coating and mated with a graphite and PTFE-filled thermoplastic bushing. The bushing’s integral brass collar facilitates mounting without nut distortion.
Shaft straightness is 0.003 in./ft and typical radial and torsional clearance between the shaft and bushing is 0.002 to 0.003 in. An antibacklash assembly is available for applications requiring additional stiffness.
Nordex Inc.
426 Federal Rd.
Brookfield, CT 06804
(203) 775-4877
www.nordex.com
Dec. 23, 2024
Dec. 23, 2024
