New Products: Beltdrive Slide
May 19, 2009
ZF1 belt drive slide is driven by a 9-mmwide HTD belt that comes in travels ranging from 153 through 2,853 mm
The ZF1 belt drive slide is driven by a 9-mmwide HTD belt that comes in travels ranging from 153 through 2,853 mm. The unit is 30-mm-wide with a 72-mm-wide carriage, making it suitable for tight spaces.
The slides have a 1.5 m/sec maximum speed and are available with 200 or 100-W (2:1 ratio) servomotors, 50 or 160 N-cm (2:1 ratio) stepper motors, or a 2:1 ratio assembly with no motor. The belt-drive pulley is 19.1 mm in diameter and has a 0.0225-kg/m specific mass.
Techno Inc.
2101 Jericho Turnpike
Box 5416
New Hyde Park, NY 11042
(516) 382-3970
www.technoautomation.com
Jan. 23, 2025
Jan. 17, 2025
Jan. 17, 2025
Jan. 17, 2025
