New Products: Minimizing Pressure Loss
May 6, 2009
The new IMH 832 Series Side Exit Chek Valve is said to provide the lowest pressure loss of any valve this size.
The new IMH 832 Series Side Exit Chek Valve is said to provide the lowest pressure loss of any valve this size. At only 8 mm in diameter, the valve features a side-exit design which permits flow in excess of 6 gpm of water at 100 psid.
The valves feature low leakage, easy installation, and robust stainless steel construction, and are typically used in industrial hydraulic applications such as off-road equipment. The valves are 100% performance tested to ensure consistent, long-term performance.
The Lee Co.
Box 424
Westbrook, CT 06498
(860) 399-6281
leeimh.com
