More than 55 different sizes of Synchrochain timing belts are now available. Synchrochain belts are designed for applications that place extreme demands on belt performance, such as maximum power transmission. The belts resist fuels, oil, grease, and cleaning agents, as well as moisture and temperatures ranging from –40 to 100°C.
The belts’ smooth back side allows the use of back pulleys. Aramid fiber-tension members have a bifilar “S” or “Z” twist, which lets the belts withstand extreme cases of starting torque, as well as shock loads and high dynamic strain. The teeth have also been reinforced on the pulley side.
ContiTech North America Inc.
136 Summit Ave.
Montvale, NJ 07645
(800) 654-0974
contitech-usa.com
