Hydraulic and Pneumatic Valves: Shuttle Valve
April 7, 2009
The 5.5 × 12.2-mm IMH shuttle valve has a nondetented, selective design to solve problems with hydraulic isolation in manifolds
The 5.5 × 12.2-mm IMH shuttle valve has a nondetented, selective design to solve problems with hydraulic isolation in manifolds. This new valve is suitable as a signal for auxiliary functions, such as hydraulically released, spring-applied brakes and load-sensing applications. The stainless-steel shuttle valve easily installs into a drilled hole, eliminating the need for threads, O-rings or in-house designs.
The Lee Co.
2 Pettipaug Rd., Box 424
Westbrook, CT 06498
(860) 399-6281
theleeco.com
Jan. 17, 2025
Jan. 17, 2025
Jan. 17, 2025
Jan. 10, 2025
