Solenoid and air-pilot-operated valves - Pneumadyne Inc.
March 25, 2009
 The new “22” Series solenoid and air-pilot-operated valves come in three and four-way configurations with 1/8-NPT (F) ports. These valves provide a 40-scfm flow rate at 125 psi and feature single or double air-pilot and solenoid operators. The 1-W, 15-mm solenoid valves use less power and have a variety of connector and voltage options. The four-way valves have a three-position version with either closed or exhaust centers. A PneuTef process permits use with lubricated and nonlubricated air. A special seal material also accommodates low-temperature applications.  Two to 10-station manifolds are available for mounting convenience.Pneumadyne Inc., 14425 23rd Ave N, Plymouth, MN 55447, (763) 559-0177, pneumadyne.com
