The single-blade centrifugal Model C100S rotary wire stripper and twister strips most insulations from solid and stranded wires, Teflon, PTFE, PVC, nylon, KEL-F, and more. Adjustments to strip length and blade depth are made while the machine is running. The stripper can be used to remove insulation slugs and twist together strands of stranded conductors.
The Eraser Co. Inc.
123 Oliva Dr.Box 4961
Syracuse, NY 13221
(800) 7724-0594
eraser.com
Dec. 23, 2024
Dec. 23, 2024
