New Products: Audio Alerts now UL Approved
March 3, 2009
Panel-mount Series KPE Audio Alerts now feature UL listing across the line
Panel-mount Series KPE Audio Alerts now feature UL listing across the line. Series TRIP remains as the nonlisted commercial edition. Both series offer sound-pressure levels up to 95 dbA in a voltage range from 6 to 220 Vac/dc or Vdc. Frequency standard is at 2800 Hz for all units. Available in either pulsed or continuous sound output as an identification means, both versions have the standard 1.25-in.-diameter mounting configuration with many terminal options. Body color is black.
Transducers USA
1400 Howard St.
Elk Grove Village, IL 60007
(888) 921- 6400
www.tusainc.com
