New Products: Single-Piece Clutch or Brake
Feb. 17, 2009
A bearing-mounted clutch and brake assembly ships as one piece, eliminating the need for assembly or adjustment
A bearing-mounted clutch and brake assembly ships as one piece, eliminating the need for assembly or adjustment. Universal mount types come with a flange for mounting a sprocket or pulley, or the unit can be designed to come with a clutch output.
Ogura Industrial Corp.
100 Randolph Rd.
Somerset, NJ 08873
(732) 271-7361
ogura-clutch.com
Jan. 10, 2025
Jan. 10, 2025
Jan. 10, 2025
Jan. 10, 2025
