Motion Products: A-B Powerflex 755 ac Drive
Feb. 17, 2009
The Allen-Bradley PowerFlex 755 ac drive comes in power ranges from 7.5-to-250 kW or 10-to-350 hp at 400/480 Vac and 540/650-Vdc input
The Allen-Bradley PowerFlex 755 ac drive comes in power ranges from 7.5-to-250 kW or 10-to-350 hp at 400/480 Vac and 540/650-Vdc input. The drive supports multiple languages, meets global standards and certifications, and spans many industries. Embedded Allen-Bradley DeviceLogix in the drive gives users control flexibility to combine inputs and outputs and perform local logic functions to determine drive behavior. An embedded Ethernet connection lets users configure, control, and collect drive data over EtherNet/IP networks. In addition, users can configure the drive to provide advanced notification of operating data on cooling fans, I/O relay cycles, motor run-time hours, and potential fault warnings.
Rockwell Automation Inc.
1201 S. Second St.
Milwaukee, WI 53204
(800) 227-6143
www.ab.com/drives/powerflex/755
