New Products: Small Servodrives
Feb. 2, 2009
IndraDrive Cs low-power servodrive is compact and supports Sercos III, ProfiNet, EtherNet/IP, and EtherCat communications
The IndraDrive Cs low-power servodrive is compact and supports Sercos III, ProfiNet, EtherNet/IP, and EtherCat communications. The drive has a universal multiencoder interface supporting Hiperface, EnDat 2.1 and 2.2, 1Vss, 5 V TTL, and Rexroth MSM servomotors. They can also be equipped with a drive-based PLC integrating motion and logic according to IEC 61131-3 standards, as well as Safety On Board capability. Digital inputs and outputs plus an analog input are on board. Also included are an integrated brake resistor, additional interface for a second encoder, and an intelligent operation panel with programming module function.
Models range from 50 W up to 3.5 kW. Dimensions are 50 × 145 × 220 mm for one unit, and 75 × 205 × 220 mm for the larger unit. Maximum current ranges from 3 to 28 A, with a high overload range. The drives work with the company’s MSM Series of motors ranging from 50 to 750-W continuous power with IP54 protection, multiturn absolute encoder, and optional holding brake.
Bosch Rexroth AG
5150 Prairie Stone Pkwy.
Hoffman Estates, IL 60192
(847) 645-3600
boschrexrothus.com/indradrive-cs
