New Products: Diaphragm Metering Pump
Feb. 2, 2009
The solenoid-driven FMM20 liquid-diaphragm pump dispenses factory set volumes of 20 μliter/ stroke
The solenoid-driven FMM20 liquid-diaphragm pump dispenses factory set volumes of 20 μliter/ stroke. The unit is field adjustable from 5 to 25 μliter and includes a choice of manifold mounting, hose barbs, and threaded ports. Available materials include PP/ EPDM, PP/FFPM, or PVDF/FFPM. The self-priming pump can run dry. With its low current and power consumption, the FMM is suitable for mobile, battery-powered appliances, as well as analytical instruments, chemical ink-jet printers, fuel cells, and dispensing equipment.
KNF Neuberger Inc.
Two Black Forest Rd.
Trenton, NJ 08691
(609) 890- 8600
knf.com
