The IndraDrive Cs compact servodrive has the support of multiple Ethernet communication buses and universal multiencoder interfaces.
Ethernet communication is through Sercos III, ProfiNet, EtherNet/IP, and EtherCat, making it suitable for the semiconductor, medical, machine-tool, printing, converting, packaging and metalforming industries.
The drive’s multiencoder interface supports Hiperface, EnDat 2.1 and 2.2, 1Vss, 5 V TTL, and MSM servomotors.
Features include digital inputs and outputs plus an analog input onboard, integrated brake resistor, additional interface for a second encoder, and an intelligent operation panel with programming module function, as well as a drive-based PLC that integrates motion and logic. Models range from 50 W up to 3.5 kW, with 3 to 28-A maximum current.
Bosch Rexroth,
5150 Prairie Stone Pkwy., Hoffman Estates, IL 60192,
(800) 739-7684, boschrexroth-us.com
