New Products: Bench-Top Wind Tunnel
Jan. 9, 2009
The WT-2000 bench-top thermal wind tunnel is made from clear polycarbonate
The WT-2000 bench-top thermal wind tunnel is made from clear polycarbonate and PVC for a durable and trans-pike, parent assembly. The unit provides highly accurate, uniform, and repeatable airflow up to 1,000 fpm. The wind tunnel’s control box allows for openloop full-scale operation of individual fans, groups of two fans, or all fans at a once. A hinged access door and access panel on the unit’s large test chamber permits fast comparison testing and use of different-size heat sinks and circuit boards.
Omega Engineering Inc.
One Omega Dr.
Stamford, CT 06907
(203) 359-1660
omega.com
