The 500 Series 200 progressing cavity pumps are designed for material-transfer and metering applications. The motorized pumps handle both clean, clear liquids and abrasive and corrosive fluids. The pumps feature a fully molded “wobble” stator, which increases the compression fit between the rotor and stator and improves performance. The self-priming units have a nonpulsating, low-shear flow that remains steady even under wide variations in the suction head. Additional features include 5-gpm flow rates; pressures to 40 psi; dual, fully sealed, prelubricated heavy-duty ball bearings; and mechanical seals.
Moyno Inc.
Box 960
Springfield, OH 45501
(877) 486-6966
moyno.com
Aug. 29, 2024
Aug. 28, 2024
