New Electrical/Electronic Products: Compact Photoelectricsensor Family
Jan. 9, 2009
The OHDK10 Spot Beam Sensor features a spot-shaped laser-light source available in 0.1, 2, or 4-mm diameters
The OHDK10 Spot Beam Sensor features a spot-shaped laser-light source available in 0.1, 2, or 4-mm diameters. The OHDK10 Line Beam Sensor features a line beam that detects objects with milled grooves or drilled holes such as printed-circuit boards. The line sensor can also detect edges on printing webs.
The FHDK10 Fixed-range Background-suppression Sensor is available with fixed 30, 50, or 80-mm sensing ranges. True background suppression eliminates signal interference related to background reflection and target color.
The FVDK10 Fiber Optic Sensor is an amplifier for plastic-fiber-optic cables. The sensor can be used with standard 2.2-mm plastic-fiber-optic cables in applications where traditional sensors cannot be mounted close to a target.
All of the Series 10 sensors feature a 10 × 30 × 15-mm housing, and a visible red-light source for alignment. Both cable and M8 connector versions are available.
Baumer Ltd. USA
122 Spring St., C-6
Southington, CT 06489
(800) 937- 9336
baumerelectric.com/usa
