New Products: 1¼-NPT air nozzle
Dec. 11, 2008
When mounted 12 in. away from its target, the 1¼-NPT Super Air Nozzle delivers 9.4 lb of blowing force — 12 times that of ordinary air nozzles.
When mounted 12 in. away from its target, the 1¼-NPT Super Air Nozzle delivers 9.4 lb of blowing force — 12 times that of ordinary air nozzles. Applications include blowing heavy materials or for surfaces where the nozzle can’t be mounted close.
The unit’s aerodynamic design ejects air through a series of holes in recessed grooves on the nozzle surface and directs it to a single point of convergence for a concentrated stream of high-velocity airflow with hard-hitting force. Air consumption is 188 scfm at 80 psig. Constructed of zinc-aluminum alloy, the nozzle is housed in a 2-in. hex body for easy installation.
Exair Corp.
11510 Goldcoast Dr.
Cincinnati, OH 45249
(800) 903-9247
exair.com
Jan. 23, 2025
Jan. 17, 2025
Jan. 17, 2025
Jan. 17, 2025
