Motion Products: Low-Speed, High-Torque Motors
Dec. 1, 2008
The WS Series of low-speed, hightorque hydraulic motors have  torque to 824 N m (7,295 lb-in.), continuous flow rates up to 76 lpm (20 gpm) continuous, and continuous pressures up to 207 bar (3,000 psi).
The WS Series of low-speed, hightorque hydraulic motors have continuous flow rates up to 76 lpm (20 gpm) continuous, torque to 824 N m (7,295 lb-in.), and continuous pressures up to 207 bar (3,000 psi). They feature a three-zone commutator valve for higher flow capacity, heavy-duty tapered roller bearings for increased side loads, and an extra-large drive link that lets these motors withstand pressure and torque spikes. Displacements start at 100 to 508 cc/rev. There are also nine shaft options, seven mounting options, and a wide variety of porting options available.
White Drive Products
110 Bill Bryan Blvd.
Hopkinsville, KY 42241
(270) 885-1110
whitedriveproducts.com
Jan. 23, 2025
Jan. 17, 2025
Jan. 17, 2025
Jan. 17, 2025
