Product Spotlight: Motorized Pumps
Nov. 22, 2008
The 500 Series 200 motorized pumps handle clean, clear liquids as well as abrasive and corrosive fluids in a variety of material-transfer and metering applications.
The 500 Series 200 motorized pumps handle clean, clear liquids as well as abrasive and corrosive fluids in a variety of material-transfer and metering applications. The pump’s fully molded “wobble” stator increases the compression fit during operation between rotor and stator for improved performance. The self-priming units have nonpulsating, low-shear flow which remains steady even under wide variations in suction head. Additional features include 5-gpm flow rates, pressures to 40 psi, dual, heavy-duty fully sealed and lubricated ball bearings. Mechanical seals are standard on all units.
Moyno Inc.
Box 960
Springfield, OH 45501
(877) 486-6966
moyno.com
