The 303 stainless steel IMH Orifice is an accurate miniature flow restrictor that is flow tested to ensure that every part is within ±5% of its nominal flow rate. The orifice’s entrance and exit conditions are closely controlled to provide more accuracy than an orifice specified by hole tolerance.
The barbed design of the orifice provides easy “press-in” installation, ensures retention, and prevents any bypass leakage around the orifice.
The Lee Company USA
2 Pettipaug Rd.
Box 424
Westbrook, CT 06498
(860) 399-6281
theleeco.com
