New Products: Miniature Slide Switches with Right-Angle Actuation
Nov. 22, 2008
A new family of miniature slide switches are for applications with restricted height or surface areas. The ultralow-profile AYZ, JS, JSM, and PCM Series switches give momentary or momentary and actuation, and surface or through-hole mounting
A new family of miniature slide switches are for applications with restricted height or surface areas. The ultralow-profile AYZ, JS, JSM, and PCM Series switches give momentary or momentary and actuation, and surface or through-hole mounting. Similar to the JS Series, the JSM Series also have positive detents, IR reflow to 260° solder profile, surface or through-hole mounting, maintained and momentary functions, and a 4-Vdc @ 0.3-A contact rating with 10,000 life-cycle operation. Available models include SPDT and SP3T.
The ultraminiature PCM Series, available in SPDT and SP3T models, come in tape and reel packaging.
C&K Components
15 Riverdale Ave.
Newton MA 02458
(617) 969-3700
ck-components.com
Jan. 17, 2025
Jan. 17, 2025
Jan. 17, 2025
Jan. 10, 2025
