New Products: Two-Way Drum Pump
Nov. 22, 2008
A powerful liquid vacuum, the Mini Reversible Drum Vac System can vacuum 5 gallons of liquid in less than 10 sec.
A powerful liquid vacuum, the Mini Reversible Drum Vac System can vacuum 5 gallons of liquid in less than 10 sec. Turn a knob and the pump empties the drum. The system’s stainless-steel two-way pump is suitable for use with most nonflammable liquids. It uses compressed air and has no moving parts to clog, freeze up, or wear out. The system features an automatic safety shut-off valve to prevent overfilling the drum, and a built-in pressure/vacuum relief is integral to the muffling body for quiet operation. Air consumption is only 19 scfm at 80 psig.
The complete system includes the two-way pump, shutoff valve, 5-gallon drum with lid and locking ring, 10 ft of vacuum hose, 90° vacuum-hose quick-release elbow, assortment of tools, and a spill recovery kit.
Exair Corp.
11510 Goldcoast Dr.
Cincinnati, OH 45249-1621
(800) 903-9247
exair.com/minirdv.htm
