New Products: Long-Distance Prox Sensor
Nov. 22, 2008
The BOD 63M Time-of-flight laser sensor has been revamped with a shorter 200-mm dead zone, a second discrete output, and enhanced resolution of less than 1 mm.
The BOD 63M Time-of-flight laser sensor has been revamped with a shorter 200-mm dead zone, a second discrete output, and enhanced resolution of less than 1 mm. The high-precision Class II laser sensor has a sensing range of 6 m and can sense minute variations in targets up to almost 20 ft away.
Two independently adjustable setpoints create an on-off window, making the sensor useful in applications such as roll-diameter detection, where the outputs are set to alert operators to change the roll.
Balluff Inc.
8125 Holton Dr.
Florence, KY 41042
(800) 543-8390
balluff.com
Jan. 23, 2025
Jan. 17, 2025
Jan. 17, 2025
Jan. 17, 2025
