The EFP MultiPosition is a doubleacting, single-rod cylinder that uses a two-piston design to provide three positions in one package. Thus, it can save space and eliminate the need for an additional cylinder. It is available in 10 bore sizes from 12 to 100 mm. Construction includes a PTFE-impregnated hard-anodized aluminum body for wear resistance, a 4301 (303) stainless- steel rod, aluminum-alloy piston with nitrile seal, bronze or selflubricating nylon bushings, and nitrile rod seals and wipers. It also has threaded front/rear mounting holes, English dimensions, and magnetic position sensing (MRS) at no extra cost. Standard options include bumpers, full flow ports, rod threads, rod extensions, and high temperature seals.
Bimba Mfg. Co.
Monee, IL 60449
(708) 534-8544
bimba.com
