New Products: Quick Conveyorheight Changes
Nov. 22, 2008
Z-Frame for the QWIK Conveyor 5200 Series easily change product heights.
A new Z-Frame for the QWIK Conveyor 5200 Series lets users quickly and easily change product heights without conveyor-toconveyor transfers. For use in the automation, industrial, and packaging industries, the frame is integrated into a single conveyor system, eliminating the need for additional pulleys and drives. The frame can be reconfigured for limitless combinations of straights, inclines, declines, and curves.
Benefits include a 15° curve segment; completely contained belt that eliminates catenary sag and reduces pinch points; low-voltage wireway with snap-in cover; QWIK Slots for simple accessory and control mounting; Sprocket Alignment key for quick belt assembly; an air and wiring management system; lengths up to 100 ft, and 250-fpm conveyor speeds.
Dorner Mfg. Corp.
975 Cottonwood Ave., Box 20
Hartland, WI 53029
(800) 397-8664
dorner.com
Jan. 23, 2025
Jan. 17, 2025
Jan. 17, 2025
Jan. 17, 2025
