New Product: Steel pressure sensors
Jan. 24, 2008
The 3100/3200 Series sensors are less than 1 in. in diameter and weight 32 gm.
Pressure sensing ranges are from 0 to 30,000 psi (2,200 bar). They deliver output signals for both temperature and pressure, providing full-scale accuracy of 0.25%, with long-term drift limited to 0.1% over the full scale per year. Sensing technology is thin film. The 3100/3200 Series transducers are available in voltage, current, or ratiometric output versions and a wide selection of electrical and mechanical connectors, pressure fittings, and mating connectors.
Gems Sensors & Controls, One Cowles Rd., Plainville, CT 06062, (800) 378-1600, gemssensors.com
