Software Supports Lean Manufacturing
July 13, 2006
Easy Lean scheduling software supports lean manufacturing and uses pull-oriented scheduling techniques.
The software lets companies coordinate purchasing with dynamic manufacturing environments to avoid material and component shortages. Easy Lean creates work orders when quantities dip below replenishment levels, and provides detailed reports and performance measurements on valueadded operations and throughput.
Infor, 13560 Morris Rd., Suite 4100, Alpharetta, GA 30004, (866) 244-5479, (678) 319-8000, infor.com
