Electro-Mechanical Actuators
June 2, 2005
SuperPac Series electromechanical linear actuators handle loads up to 2 tons in tension and compression, and travel speeds to 50 ipm.
Stroke lengths range from 3 to 24 in., and custom lengths are possible. Rotation is reversible and torque capacity is the same in either direction.
SuperPac actuators have fully gasketed aluminum construction with zincchromateplated translating tubes, double-clevis ends, and optional trunnion mounts. Other features include camtype adjustable internal limit switches with optional potentiometers, ac or dc motors, and metal gears. Drive systems are available with either ball screws or Acme screws.
Duff-Norton Co.
Box 7010
Charlotte, NC 28241
(800) 477-5002
duffnorton.com
Dec. 12, 2024
Dec. 12, 2024
Dec. 12, 2024
Aug. 29, 2024
