UV-Cure Adhesive/Potting Compound
May 10, 2007
The electronic-grade UV Cure 60-7108 is a low-viscosity curable adhesive and potting compound that maintains its clarity over time.
The electronic-grade UV Cure 60-7108 is a low-viscosity curable adhesive and potting compound that maintains its clarity over time. The compound self-levels in and around electronic components, adheres well to most substrates, and has excellent exterior durability.
Epoxies Etc., 21 Starline Way, Cranston, RI 02921, (401) 946-5564, epoxies.com
