Peristaltic Pump
Jan. 11, 2007
To meet the fluid-handling needs of beverage-dispensing equipment, the 400 F/D Series peristaltic pump can be configured for two or three channels with individual spring-loaded tracks to deliver channel-to-channel accuracy and maximum tube life.
Each tube track can operate with different tube diameters to let a fixed ratio be pumped between two fluids. The inherent-metering pump, with a 99.5% repeatability, performs dosing, metering, or evacuation duties. An adjustable occlusion lets users adjust the track to deliver the required pressure (pumps with preset occlusion are also available).
Watson-Marlow Bredel, 37 Upton Technology Park, Wilmington, MA 01887, (800) 282-8823, watson-marlow.com
Dec. 12, 2024
Dec. 12, 2024
Dec. 12, 2024
Aug. 29, 2024
