The system’s tough outer shell prevents contamination by dust and water. The panel-mountable devices combine overtighten protection and a gasket for sealing. The receptacles feature “molded-in” threaded inserts for tamper-evident installation, and a detent mechanism that both increases token retention and gives users tactile confirmation when an inserted token is physically engaged. A “self-wiping” action cleans the contacts with the insertion and removal of each token. The receptacle has a minimum contact life of 50,000 insertions/removals.
Datakey Electronics Inc.,
12730 Creek View Ave., Savage, MN 55378,
(800) 328-8828,
datakey.com
Dec. 23, 2024
Dec. 23, 2024
